Old 07-19-2014, 02:18 AM   #7
Shehadehd
Shehadehd's Avatar
The micro switch at the locks can be checked by pressing your finger in the groove until you get a button press. The following test will prove the micro switch works: Fully depress the micro switch with you finger and hold. Then roll up the windows until both are fully closed. Now release your finger from the micro switch and the windows should drop a little. If the windows don't roll up all the way when you are pressing the switch, or if they don't roll down some when you let go, then you have a microswitch problem.
The convertible relay will come out but you will need to shimmy it a bit. The best you can do is remove it and put it back in to see if it just needed reseating.
If your ebrake light comes on and off, your ebrake switch is okay.
Accessing the rocker switch requires you to remove the bezel on your front console. This is not hard at all. If you get to the point where you need to remove it, I'll post a video of how to do it.
If you are interested in a Comfort-Top module, please visit:
https://www.enhancedautomods.com/shop/comfort-top
Shehadehd is offline   Reply With Quote
