Old 07-18-2014, 09:02 PM   #10
BFeller
I was bored @ 10:30 pm tonight. The OBC Stalk got installed. Works like a charm. I did the install without removing the steering wheel. Since there already was cruise control it meant that the stalk for the OBC could be added to the three stalk assembly that was already in place. The top trim pice for the column had to be removed. It was easy to do by rotating the steering wheel to accessmthe screws holding it in place behind the wheel, along with extending the adjustment of the column to its longest position for access to the trim screws on the side. If any one else is confused as to what plug the new wires go into it is the center plug. Less than two hours later it was buttoned up and out for test drive.
