Old 07-17-2014, 04:08 PM   #2
JFP in PA
Originally Posted by jdraupp View Post
Thanks for the responses guys. JFP, that's a little chunk of info that I haven't heard before. Makes some sense actually. Car always smells rich at startup.
Only one of the O2 sensors was replaced...should I replace the other pre cat one and see what difference that makes? I don't have a durametric but I'll try and get some fuel trim data. Is it possible that all four o2 sensors need replaced?
JFP, regarding the leaking injector, is there an easy way to tell which one would be leaking? the fact that I've got both 1128 and 1130 means it would have to be at least one on each bank right?
If you have a leaking injector, it should show up both in your fuel trim values and by looking at the plugs.
I'm not a fan of swapping out O2 sensors unless they check out poorly. They can be tested in place using the Durametric system. These things are too expensive to change out unless they actually need to go.
