Old 07-17-2014, 10:05 AM   #3
Smallblock454
Hi,
well first for DME 7.8:
P1128:
360 Oxygen Sensing Adaptation, Idle Range, Bank 1 - Below Limit, 360 Oxygen Sensing Adaptation, Idle Range, Bank 1 - Above Limit
P1130:
361 Oxygen Sensing Adaptation, Idle Range, Bank 2 - Below Limit, 361 Oxygen Sensing Adaptation, Idle Range, Bank 2 - Above Limit
360 Oxygen sensing adaptation idle range, bank 1
361 Oxygen sensing adaptation idle range, bank 2
Means the problem is reported at idle - so to say at very low revs.
Do you have a modified exhaust system? Did you check if your exhaust system has no little leak - especially manifold and monifold bearings?
Where both lambdas replaced, or only one?
Regards
Markus
Smallblock454 is online now   Reply With Quote
