Old 07-17-2014, 01:19 AM   #1
Smallblock454
Originally Posted by jdraupp View Post
Looks like chain tensioner pad wear which would explain your cam shaft deviation. Fixable.
Hi,
i agree concerning the pad wear, but how will you fix that?
OK you can echange the tensioners in a first step. But if the pads are really weared out they need to be replaced. If they are really weak they can also brake.
To replace the pads i think you have to pull the engine. Don't think you can do a replacement of the pads while the engine is in the car. If you can do it while the engine is in the car, please tell me how to.
Thnaks & Regards
Markus
