Old 07-14-2014, 11:01 PM   #1
BrandonJames89
Just a side note about using HIDs for high beams:
Most companies and individuals don't use HIDs as a separate high beam because of the time it takes for the bulb to get to normal operating temps. If you use them for long periods of time in remote areas where you aren't blinding people then they might be better. They won't be very effective flashing for a warning and the short on/off period will most likely greatly reduce bulb life.
Bi Xenon headlights are usually the only ones to use HID bulbs as a high beam and that's not how the litronics were designed.
BrandonJames89 is offline   Reply With Quote
