Old 07-14-2014, 06:04 PM   #1
DG Boxster
Did I blow my AOS autocrossing? Help me diagnose it!
I did my second SCCA autocross yesterday in the 98 Boxster (72K miles, unknown maintenance history). I've owned this car since May, and have driven 3000 miles now.
About 2500 miles ago I changed the oil. I filled it using the dipstick and it came out full scale on the electronic meter (maybe overfilled - one square past the line). I didn't know about the electronic meter then.
2500 miles later, with no problems. I often (but not every time) check the oil with the electronic meter, and it has always been the same, one square past the line.
After yesterdays autocross I drove home (20 highway miles) and put the car away. A couple hours later I decided to wash it. I started it to back out and there was a big puff of smoke
I left the car in the garage overnight and all day. I started it this evening and check the oil level with the meter. It was two squares under the line. I started it, and there was a big puff of smoke. It lasts maybe 2-3 seconds then is over.
I pulled the car out and let it idle to warm up. I shut it down, waited a little bit, and restarted with no puff. Engine was still warm.
I then drove it normally for 20 mins or so, came home, shut down. Waited maybe 15 mins, started again. No puff. Interestingly, the oil level on the electronic meter reads only 1 square low when the engine is hot. Not sure I really trust the electronic meter.
Tomorrow when it is cold I'm going to check the oil with the dipstick, then with the electronic meter, then start it. I'm expecting the big puff.
So, can you guys help diagnose this?
  • Is there a chance my AOS is OK? Somehow the lateral acceleration in the autocross forced some oil somewhere it shouldn't be?
  • Is there a chance my AOS is just partially failed?
  • Is there a test I can do to be sure?
Most important question: Should I drive the car if I get a big puff in the AM?
Second most important question: Who is going to help me change out my AOS if it is failed?
PS - I forgot to mention - this all happened right after I took off the bra in the front.....maybe she's mad ?
Here is a link to a video of my poor autocross driving. Don't make fun of me, I'm learning.
https://www.youtube.com/watch?v=tfUeUq2_06E
DG Boxster is offline   Reply With Quote
