Old 07-14-2014, 02:53 AM   #1
BrandonJames89
Originally Posted by Chronohunter View Post
So the cause seems to be my aftermarket HID high beams. I have now had several different random warning lights come on when I switch on the high beams. The warning lights stay on until the car is turned off. Everything operates properly just the warning light(s) come on. The headlights operate perfectly. It seems to stop happening after 10 minutes or so of driving if you turn the car off and restart it. I have had oil pressure once battery twice and rear spoiler once. I hope there is a solution because the stock high beams are horrible! The HID's are seemingly good quality and supposedly "OBED2" compliant and they work great (besides the warning light issue).
Anyone else seen anything like this before... I sure haven't!
Suggestions welcome
Did you install a relay to get power from the battery directly? When the ballast is drawing current at start up it is probably dipping your voltage at the other components too low and setting off the warning lights. Could also be electromagnetic interference from the ballast. Make sure the ballast is placed far away from other electrical components and grounded properly to the chassis. Because your battery light comes on when you turn the lights on I'm guessing it's because of the current draw the ballast requires on start up. If there is no relay, try installing one first, if not, ground and shield the ballast or move it to another location.
I'm assuming it starts up fine after driving more aggressive because you are getting the voltage levels back to normal using the alternator. If you have a multimeter get a voltage reading at some part of the circuit and have someone flip on the HIDs to see if there is a drop in voltage when the lights are turned on.
BrandonJames89 is offline   Reply With Quote
