Old 07-13-2014, 12:34 PM   #11
woodsman
woodsman's Avatar
well if you are handy, as it is evident given your results, you can do the wheels yourself too. There was an Issue in Excellence that told you how to fill in the rash with a product called 'HALF TIME' (link below), and the same sort of spray you used for your wheels. The article showd you how create a cardboard enclosure so that to keep the paint of the rubber. There's also the second link which has been around for a while, I didn't have such great results using their filler.
HALF TIMEŽ One-Step Filler & Glazing Putty
BMWTips wheel-scuff repair
I'm surprised Excellence recommended using 'half-time' as it's meant to be used in very thin layers for filling pinholes in bondo as a final step before priming. And while I can accomplish whatever I wish with bondo, I to have never had great results with half-time- It cures to a VERY hard surface which makes it difficult to sand and feather. Once you break through the 'skin' it's soft and sands away too fast. It is the last thing I'd use for wheel rash.
