Old 07-12-2014, 06:07 PM   #11
dghii
[QUOTE=Paul Ri-Chard;409651]
2. The b pillar switch goes just in front of the defroster connector. There should be a 8mm bolt that tightens the switch assembly to the frame. I'll try to get a pic.
DO NOT OPERATE TOP WITHOUT THE B-PILLAR SWITCH IN POSITION as you can over rotate your transmissions and get things all out of whack (ask me how I know). Your top will not know it is up without a signal from the B pillar.
QUOTE]
I hope I didn't screw things up too bad. I have been operating the clamshell only... kind of a semi-automatic mode...by pushing the dash button and holding the microswitch down manually near the end of the close cycle (front pushrods are not connected yet). I initially synched the transmissions, but a couple of times I heard a pop from one of the transmissions when I let the motor run a little too long. I'm assuming the cable simply popped or skipped over the plastic gear, and that I didn't break the gear itself. I will disassemble and inspect and resynch the transmissions and hopefully figure out how the microswitch gets mounted and try it again.
I'm glad you had the push rods disconnected! Take your time and get the b-pillar switch connected and you'll be fine. I'm not sure why your installer would have moved or disconnected the switch.
