Old 07-11-2014, 10:26 PM   #4
Paul Ri-Chard
Originally Posted by papasmurf View Post
like others have said, the helper straps (6-7" long) are useless on mine and the guid cables were always falling outside the window trim piece. The solution was that the small springs at the bottom of the b pillar (right above the rear door seam) were inverted and needed to be flipped around...took about 5 minutes to do (will need torx I think) and no disassembly of the top is required.
Thanks Papa, I will 'flip' the springs tomorrow to see if that helps with the tracking. Its good to get feedback from the group after you shell out $750 in labor only to be dissappointed.
Paul Ri-Chard
Paul Ri-Chard is offline   Reply With Quote
