Old 07-11-2014, 06:04 PM   #3
ilikeching
Usercpy
ilikeching's Avatar
Originally Posted by papasmurf View Post
like others have said, the helper straps (6-7" long) are useless on mine and the guid cables were always falling outside the window trim piece. The solution was that the small springs at the bottom of the b pillar (right above the rear door seam) were inverted and needed to be flipped around...took about 5 minutes to do (will need torx I think) and no disassembly of the top is required.
Hey, that's a great tip.... thanks, will try this later....
http://www.flickr.com/photos/flickr_ching/
ilikeching is offline   Reply With Quote
