So I attempted to install a VW door lock assembly that I found new for 35 dollars just to try it out because it looked nearly identical. Turns out it was the same except for an 8 pin connector when my boxster has 9.
I took the original one apart again and fixed the reversal of the microswitch engagement piece and the car will at least lock again but I noticed that the key in the door does not do anything still.
Does anyone know what could be causing this? The lock cylinder feels the same when rotating the key it just doesn't respond to it. The remote works fine however.
