Old 07-10-2014, 08:16 PM   #569
particlewave
Who cares if someone else likes it or not! What you have so far is pretty cool looking. I am also curious about the outboard LED's.
Funky! Quick question... those shotgun LED projectors, how do they hook up to the system? Are you planning to connect them to the parking light or the low beams? Fogs? Standalone circuit?
You need to put on the inner trim and the lens then fire it up so we can see what it will look like
(curious!)
I'm not sure yet.
They will either be DRL's or "flash to pass" daytime high beams. They are very bright. Blinding.
Combine that with the projector lens and they are actually very useful.
I mostly just like the way they look, though.
I'm resurrecting the old CCFL DRL idea, also. These will be nice because I made them so that the bulb can be changed through a plug in the side of the headlight (no need to remove the lens). They are also very bright.
Still a bit of work to go, but I'll have them finished in a week or so.
