Originally Posted by myn8m3is8ndy
I was installing some cat bypass pipes.
I removed the muffler. then removed the 2 rear cats.
I Installed the bypass pipes.
Then tried putting the muffler back on BUT now the bottom screws in the middle of the muffler wont go back in.
SO, My question is, is it okay for my muffler to just hang on the top mount??
You need the bottom bolts. If the originals are lost or damaged you can use just about any nut & bolts.
