Thread: Boxster V8
Old 07-07-2014, 12:58 PM   #11
mikeman
yeh stock...
good little thread over here:
L33 5.3 na performance build recipe - LS1TECH
Here is my aluminum 5.3 build:
18K mile 2007 LS4 (aluminum 5.3 w/799 heads): $1000 for engine transmission/harness/ecm.
LS7 MAF: $60 for sensor and pigtail
LS2 TB, Intake, & Injectors: $375
224/232 DoD camshaft, springs, pushrods: $750
LS7 exhaust manifolds: $150
Reworked stock harness: $50 (for pins and heat shrink)
Never pulled the heads or did any porting, just bolted together and tuned.
So $2385 for the basics, or $1810 after I sold the transmission for $575. Best part is when I break it, I can just get another LS4 engine, swap over the parts and do it again. Resulted in 382whp at 6800 rpm and 335 wtq at 5000
and CarCraft..
Dyno Numbers
Test 1 was the baseline test for the stock 5.3L with a GM Performance Parts single-plane intake manifold, a Holley 750-cfm carburetor, and a set of Hooker 13/4-inch headers complete with a 21/2-inch exhaust system and Flowmaster Super 44 mufflers.
Test 2 was the same engine with the only addition being the Comp Thumper hydraulic roller camshaft.
*snip*
TEST 2
peak HP 433@6800rpm
peak TQ 381@5400-5600rpm
Read more: 325 Chevy Small Block Engine - Bolt On A Cam And Heads And Add 120+HP - Car Craft Magazine
mikeman is offline   Reply With Quote
