Originally Posted by Jager
Use your Durametric to look at the O2 sensors ahead of Catalytic converters, with the Air Pump not running, you should have alternating voltage readings between 0 and .8 volts. You can compare bank 1 and bank 2.
I dont have a code tool, but i had the check engine light come on,so I went to autozone and I was told it was an O2 fault, it was reset but came back a while later, how many O2 sensors does my 99 boxster have? (2)? Thanks in advance.
