you can find the door speaker enclosures on eBay, probably door panels as well
If you do a Google search, IIRC, there is a DIY for adding them
To add the wires will be a PITA. In addition to running the wire, you may need to add pins to the connectors in the door
The door speakers are subs. I am thinking of putting a powered sub under the right seat. The problem is the space under the seat is about 3/4 in to shallow, so I need to raise the seat tracks
2004 996 Targa Tip
Instructor - San Diego region
