Old 07-04-2014, 12:35 AM   #2
Steve Tinker
Steve Tinker's Avatar
Charge the battery for at least 10-12 hours - the clicking is the starter solenoid failing due to low voltage.
You will have to open the frunk (if your car has the electrical opening device, check your handbook for correct procedure), then remove the cover over the battery.
To charge the battery connect red cable connector to + and black cable connector to -.
NOTE: use a battery charger and not a battery tender (maintainer).
2001 MV Agusta F4.
