Thread: throttle blip
Old 07-03-2014, 05:11 PM   #4
The Radium King
The Radium King's Avatar
seningen - you're right, logic might not be required - it might be able to be done with relays - relay on the clutch pedal in series with a relay on the brake pedal in series with an on/off switch. if all on then triggers a third relay that pulls the 'blip' resistor into the throttle circuit. the art becomes the duration of the blip (ie, perhaps not for the entire time that the clutch is depressed) and when the blip happens (ie, not immediately when the clutch is depressed, but almost just before the release of the clutch). there are various types of timed relays that might serve the purpose.
