Only thing to add is relatd to the key, be aware of the position of the wheel and the wheel lock. If the column is locked it can be difficult to get it unlocked and that can be seem like the key is hard to turn. In summary, keep the wheels straight ahead and don't lock the steering...unless you have a specific need. If you do this and the key is hard to turn, there is a mechanical and electric component that may be the issue. The failure of the electrical component is common and (debatibly) easy to replace. Just don't take it to a dealer as they will change both and charge $$$$...search, lots of info...
