Originally Posted by Miata2Boxster
Great to know, thanks! Do you know how I might test the ignition switch to see if it is the culprit in this instance?
If it's not completely shot, you can put in your key, turn it to the on position, and push it in and out and wiggle it a bit and see if the windows magically start working again.
I had some electrical window issues when the microswitch in the center latch for the top was going out. Reseating the center latch by opening the top, sticking my finger up into the hole to actuate the microswitch, then re-locking the top worked for me.
The blowing fuse thing is bothersome though and I think you have a short somewhere, not one of the things above. Just an afterthought to pass along.
Let us know what the culprit was in the end. Others reading this thread in the future will stumble on a solution to their own blown fuse window problems.
