Switch not Stalk Harness
This would be from the back of the Instrument Cluster (Gray Plug) to the switch located on the left panel of switches in the center cluster right ?
I could include extra length of wire in case you needed to reroute the loom. This would be no problem. Would you want standard push on (Stakon) connectors for the switch (s) ?
