Originally Posted by Flavor 987S
Was everything normal prior to this cleaning?
Check for water under the passanger seat. Hopefully nothing was damaged. Maybe a loose connection????
Hi, thanks for responding. Yes, everything worked fine prior to and immediately after steam cleaning the interior. The following day is when the issue with the windows not retracting manifested. I saw no visible signs of water build up or condensation.
The fuse that keeps blowing is C3 not D3 as I indicated in my initial post.
