If you have all of the parts beforehand, 5 hour fix at maximum, assuming you've used a wrench before.
That time includes getting under the car and pondering around all of the other interesting looking parts that you haven't seen before.
The coils are two bolts and a wire plug each to swap. This part will be sort of expensive.
The plug tubes normally only need new O-rings and this will be cheap, even to do all 6 tubes (12 O-rings).
