Old 06-30-2014, 06:47 AM   #22
amitmishra4
dghii,
So you are thinking that even though the alternator and regulator passed the tests at the local pepboys with flying colors, that could be the case? Their tests are not always accurate?
Jager,
I bought one of those battery/charging system testers from the auto parts store and with the car running on idle when I clamp the positive and negative, it comes up to around 13.4 or so(which is labeled in red on th meter. Green is above 14V). There is a load button on the tester also, when I push that, it drops to 12 V(slightly above maybe). Does that make sense?
I will post pictures when I get home tonight so it's clearer if I'm not able to explain it correctly.
2001 Seal Gray Boxster (Hair Salon on wheels)
2013 Audi Q5 (Family Mover)
2006 Yamaha R1 (Adrenaline Machine)
amitmishra4 is offline   Reply With Quote
