Driver Door Lock Not Responding
Over the past few months I've had an issue with the doors and key remote. Randomly when I would lock the car with the remote or unlock it I would get a double beep and the drivers side lock would either not open or attempt to lock then unlock itself. I could use the key to close the door when this would happen and it worked as expected.
Both doors also needed almost a fast double pull to get the mechanism to release as well like something was catching on the lock. This was worse in very hot weather and it didn't want to open sometimes.
Yesterday I took the door panel off and removed the driver side lock assembly to attempt a repair. When I reinstalled it and connected the battery the lock button on the dash was lit up and would not let me turn it off. With the door closed I can turn it off and the locks attempt to move but it immediately lights back up and the car double beeps again. Door handle operation seems smoother now and all other functions like windows and indexing are working. The big issue now is that the driver door is not locking at all. It will not respond to the key turning or the button on the remote (I do hear the motor run with the remote though).
The repair included checking all the solder joints, checking continuity, cleaning connections and lubing mechanical surfaces in the mechanism. What part of the assembly has control over the lock itself (a specific microswitch etc..)? It seems like something wasn't done right during reassembly of the mechanism. Any help or instructions to check for reassembly would be appreciated. By the way after I lock with the remote the trunk and hood latches do not release and the passenger door is locked, only the driver side lock mechanism isn't closing.
