Old 06-26-2014, 08:53 AM   #3
truegearhead
truegearhead's Avatar
My suggestion to max your AX class:
1. Run 235/255 in the exact same tire. It matters. 35 psi hot
2. Alignment specs: Max front camber (-.7?) with a touch of toe out.
Rear camber (-1.2) with a touch of toe in.
3. M030 rear sway to rotate the car more easily anytime you lift.
$. Pull any excess weight within the rules.
This will only cost a few hundred $$ and might be worth .5 sec.
Excellent! I think this is some may be the route. So you think a 235 will work? It sounds like some people are stretching 325s on a 7" wheel on other cars (like Miatas) but I've never heard of it on a Boxster. Also you think the rear is sway is more benefitial than a M030 front? I've heard people on both sides of the fence.
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
truegearhead is offline   Reply With Quote
