Originally Posted by truegearhead
I'm running 255 Rivals in the back and Hancook RS3 225s in the front (Rivals don't have that size) but both tires are as competitive as you can get and are apparently very close in carateristics. As I mentioned below I really think I could stretch a wider tire in the front given the stiff nature of these kinds of tires.
They sell a 235/45/17 Hancook RS3. Think that would fit on the front?
My suggestion to max your AX class:
1. Run 235/255 in the exact same tire. It matters. 35 psi hot
2. Alignment specs: Max front camber (-.7?) with a touch of toe out.
Rear camber (-1.2) with a touch of toe in.
3. M030 rear sway to rotate the car more easily anytime you lift.
$. Pull any excess weight within the rules.
This will only cost a few hundred $$ and might be worth .5 sec.
