Old 06-25-2014, 05:39 AM   #1
Heiko
Heiko's Avatar
Undo the two horizontal pipe mounts that go towards the front of the car... if you undo the two inner bolts the lower part of the bracket slides out of the upper part and the two pipes come loose. This allows you to flex the water hoses a little further at the back to get the mount out. Don't be afraid to bend those big rubber hoses a bit at the back - they wont break! Lowering the engine helps but be careful because the exhaust tips will contact the rear skirt and pry upwards if you lower it too much.
If you jack your car up from the rear only the engine will want to come forward slightly once you undo the mount in the front... its easier to do when the car is level... just sayin'
H
Previously owned:
