Still off
Hi all, found this thread, tried the fix with the bike brake adjuster to fix the lack of window drop. Seems to have helped, but the window now needs to go up another 3 or 4 mm, and when it goes down it seems to go too far. It starts to twist the window guide when the window sits down on the down stop from the motor pull. Tried adjusting the upper stops, and tension with the brake adjuster. I'm worried I may in fact need a regulator ?
Thoughts ?
