ok guys, so i went ahead and painted my trim pieces also. for the most part it turned out pretty good. the pieces turned out really good after i put on the enamel. but then two of the pieces i thought didn't have the gloss i wanted along the edge so after about an hr i sprayed them again with the enamel and ! the gloss went away. it seemed like the enamel ate into the paint and now its dull.
can you guys give me advice at this point to retain that gloss finish? should i wait a few days to let it dry and enamel it again or do i need to put on the base coat again and then enamel again?
thanks for your help in advance.
