Originally Posted by Fintro11
That is a very stupid idea to say the least.
Most highways should be raised to at least 130 kph
Speed is not the major problem, it's when you have some one going 130 compared to 90 kph is when you have a problem. The speed difference is the danger. You are coming up so quick on the other guy chances are he will not see you coming and that's where a lot of accidents happen. It is a lot safer if every one is going the same speed either faster or slower.
That isn't the case in Germany, passing does need serious reform though as there is a major respect for only using the left lane in the case of passing in Germany. As for the comment about trucks passing being a major problem, this would likely be more suited for a 3 or more lane highway with no trucks allowed in the left.
