Old 06-18-2014, 08:25 PM   #6
amagalla
amagalla's Avatar
Stereo upgrade process
So... I'm now going through the process of upgrading the ENTIRE sound system. I've upgraded the front speakers to Polk db401, I added 4 db350 s to the rear box. I'm changing the door "sub-woofers" with some Kicker CVT65 units. I'm also adding a JVC Nav system (kw-nt800hdt) and a JVC amp in the frunk.
I think this will be the hardest part as I've elected to modify the existing box. This is my progress on that so far.
This is the chaos so far.
Here is the navi unit. I don't know what the camera was focusing on.
This is the Amp install. I'm quite impressed with the install if I do say so myself.
Here you can see the 2 Polk speakers peaking out from the speaker material.
The climate control relocated without a problem.
This is where I got the switched power from. It's phone accessory harness behind the batwing.
I hope to have everything done by the weekend. Let me know if you have any questions.
Thanks.
Tony
Lapis Blue 03 Boxster S
