Old 06-18-2014, 09:52 AM   #2
amagalla
amagalla's Avatar
You can also get switched and unswitched 12v from the car phone harness/connector under the batwing area
There are a re posts recently that detail that
Those fuse block adapters are also available at autozone and other autoparts stores as well
This is what I ended up using. The only thing that I haven't been able to confirm is the speed signal as the car has not yet come out of the garage. Everything else woks perfectly. The last thing that I need to do is to modify the door baffles to fit some Kicker 6.5 in sub-woofers. everything else is working perfectly.
Lapis Blue 03 Boxster S
