Originally Posted by recycledsixtie
Thanks for asking. It is code P1341 which according to my indy shop is the variocam actuator bank 1. I have ordered the camshaft position sensor which two parts guys say will fix the problem. I am going to let my local low cost indy shop fix it(the owner does have a Boxster as well). If he is not up to it I will take it to a higher cost indy shop that does good work.
I just received a brand new water pump(plastic impeller) from Pelican Parts yesterday even though the current one is not broken. 13 years old it is time to change it. Of course the CEL light steady came on after I had ordered the first set of parts.
Do you agree that I should not be driving the 2001 base Box with this fault on?
Do you agree with the fix of the code?
Cheers, Guy
How much is it to fix this, there is local Craigslist car for like 5k with this problem, maybe I could make a buck off of it.
