Originally Posted by Treg23
Thanks all. The base has the higher sidewall tires while the S usually seems to have a much lower profile tire with 19s (maybe this is the way the dealers kit them out?) which I reckoned would stiffen up the ride quite a bit compared to the 18s and higher sidewall on the base.
I see Perelli P zero on a lot of Boxsters. Is this the go to tire for all round use?
Tire selection will make a huge difference in your ride comfort. Tires are the cushion between the road & your car. 17" wheels & tires selected for comfort will transform a Boxster. I would not consider Pirelli's, usually overpriced for what you get. Go to tirerack.com & read ratings for ride comfort.
