Old 06-11-2014, 01:23 AM   #20
peterbrown77
If you leave the key in the ignition, the stereo stays on. If your ignition switch is failing, even after you remove the key it still thinks the key is inserted. You should hear a definitive "click" when you remove it, if not it's still "on".
2002 Boxster S, Arctic Silver, 18" Turbo Wheels, 6-speed
peterbrown77 is offline   Reply With Quote
