Old 06-10-2014, 07:45 AM   #24
The Radium King
The Radium King's Avatar
did a bit more checking. the gt3 uses the same radiator duct and bracket as the 986, so assume the gt3 radiator is the same orientation as the 986. assuming the body attachment points are the same, you should be able to just swap in the two-piece gt3 fender liner for the one-piece boxster unit. this will give you an oem blocking plate for the bottom of the bumper, and oem venting into the wheel well to aid in brake cooling. I think the gt3 unit allows a bit more room in the wheel well as well, should you want to run wider tires. these little babies should seal the deal:
997.575.231.91 and 997.575.232.91 brake ducts
