Old 06-09-2014, 09:15 AM   #17
Ian c
What a load of nonsense .
That's like saying an electronic throttle is to blame and we should go back to throttle cables .
It's automatic. The software is actually changing the gear, not a direct hand-on-gear lever-to-trans interplay. The software will even allow you to mess up a down/up change to make you think you're doing the actual gear shift. It's either a mechanical transmission, where the driver does the physical shift, or its HAL doing the shifting which makes it an automatic. Or in the case of PDK a sporty automatic. It's also part of the reason why racing is so boring and so few drivers can overtake (cleanly) anymore.
Ian c is offline   Reply With Quote
