1) try getting the front tires balanced. If at all possible, find a shop with a RoadForce balancer. I've had this happen a few times, particularly w/ my autocross tires, and re-balancing always cures it.
2) Your headlight switch is going bad. When you turn the lights on, pull the switch out (turns on fogs) and then tap it in forcefully with the heel of your hand.
Rennzenn
Jfro@rennzenn.com
