Old 06-08-2014, 07:05 AM   #9
JayG
On the slippery slope
JayG's Avatar
Originally Posted by BFeller View Post
I have worked my way around through all of the USB ports on the laptop. I am going to try another laptop this week.
The connector of my cable gets warm - not hot - but warm. Is that normal?
Which end? USB or OBDII ?
You might also try Durametric Ver 5 and see if you have the same problem. You can download it from their website
Double check the POWER SAVING settings on your laptop, It might have the ports set to sleep after a short time. Although I would think that the Durametric software when active is polling data, so it should keep the port active
It is too bad the software doesn't work on a Surface, they are nice compact lightweight computers.
I also don't understand the Durametric issue with using an inverter. the laptop is isolated through its power supply. Only thing I can think of is power draw through the cars 12v system might affect the readings????
2004 996 Targa Tip
Instructor - San Diego region
