Old 03-15-2006, 01:41 PM   #1
MNBoxster
Hi,
Good Job! I hope you also bled the Clutch Slave Cylinder too because they share the same reservoir and you don't want the old Fluid in the Clutch Hydraulics to contaminate the new Fluid and also, it's possible to get Air into the system.
I've used the Motec Bleeder for several years on a number of Cars and it works quite well. But, I recommend that you get the Swivel Adapter for the Cap. The OEM Motive Cap does not swivel, meaning that to screw it on, you need to rotate the entire Bleeder, very inconvenient when filled and also increases the risk of getting some Fluid on the Paintwork, especially when removing it. I think Motive charges something like $45-$50 for it, but you can get it for $24.95 (+S/H) from Zims Autotechnik - www.zimsautotechnik.com or: http://www.zimsautotechnik.com/acatalog/Metal_Swivel_Cap_for_Motive_Products_Power_Bleeder .html . Makes working with the Motive a lot easier. Well worth the expense...
Happy Motoring!... Jim'99
