Will
Hi Dlirium
When I get the replacement I have ordered I will tell you if it corrects the problem.
It would seem though as mine only opens on HI for hot air and then shuts when moved from Hi and the fact that the servo graduates the opening for the temp scale where mine is shut tight this will correct the problem.
On my UK car the servo is in the passenger side footwell on the underside of the heater box, not hard to do from what I have seen.
Cheers
Neil
