Make sure you use "Extended Life" type (OAT) rated anti=freeze, so that it is compatible with the Porsche coolant. Otherwise you are going to make your coolant into gel. You don't have to buy Porsche specific coolant, buy Havoline Extended Life Coolant and you will be perfect. Porsche $35 per gallon, Havoline 16 per gallon at O'Reillys
