Old 06-03-2014, 09:54 AM   #2
particlewave
The pins are fairly easy to remove. I just insert a small flat blade screwdriver into the slots on either side of the pin and twist it to flatten out the little flares that hold it in. Once this is done you can simply push or pull the pin out through the back.
If you're sure you need a replacement pin, PM me.
I have some...
