Thread: Cabin air feed
Old 06-02-2014, 02:36 PM   #5
schwank
Yeah that's where the cabin air filter is, but I would assume it gets vacuum pressure from the HVAC fan. Your setup would likely inhale some water too if I tried that here in the PacNW.
You could also run a similar type of NACA duct in the front of the passenger side window, I have seen a lot of racers do that. Probably harder with the frameless window though.
For my build plan, depending on the type of hard top I install I am thinking of integrating a NACA duct directly into the top. I have a Stilo helmet with direct air feed but you could also just pump it right in front of the driver.
life is participation in evolution
87 944 PRO44 racer. 01 986S (race build in progress), 93 968
schwank is offline   Reply With Quote
