Old 06-02-2014, 12:43 PM   #5
tsasu360
Hi All --
Ian_C -- if the passenger door is open is when the problem occurs, the window goes down, then it does not go back up. If I close and open door repeatedly it stays in the 1" down position (i.e. it does not go down 1" every time).
steved0x -- I take back what I said earlier; it turns out that the light in the rear of the doors (internal light) does stay on when the passenger door is closed; does this mean the door thinks it's open?
Also why would the door open/closed switch be in the door handle, or is it part of the latch mechanism and door handle?
Thank you...
tsasu360 is offline   Reply With Quote
