Old 06-01-2014, 11:44 PM   #5
Ashmyster79
Ashmyster79's Avatar
Send a message via Skype™ to Ashmyster79
When you put it back together, be sure to torque the long studs into the body at the proper torque. If you just put them in finger tight, when you but the bolts on them, they will pull out of the body and you will be in a world of doo doo.
Most of the write ups on motor mount replacement omit this very important step.
Thanks for the tip. I got them ratchet tight but will go back under in a day or two and torque them see if they have come loose.
Ashmyster79 is offline   Reply With Quote
