Thread: AutoTop DIY
Old 06-01-2014, 08:39 PM   #11
JayG
On the slippery slope
JayG's Avatar
Take a meter and see if the transistors switch ....
Originally Posted by Shehadehd View Post
I just wanted to make sure that the Base voltage was okay to put the transistor into a saturated state and that the resistor wasn't too small and causing the output pins on the board to overdrive or not providing enough base current for the collector current needed.
you guys are great and thanks for your help
I'm gonna breadboard it this week and see if it is switching correctly
I'll post an update once I have a chance to test it
I put everything back to stock for now and at least the top still works correctly
At least I now have a switched 12v line in the upper console. I connected it from the unused phone connector in the bottom of the console
thanks again
2004 996 Targa Tip
Instructor - San Diego region
